IAS RADIUS Authentication with WPA
Answered Question
Jan 20th, 2009
I have an 1131 that I am running stand-alone (autonomous). I am looking for an config example on how to set it up to autenticate to my RADIUS server (running on my domain controller), and use WPA encryption. So far all I can find are configs for AP using WLCs. Can anyone help? Thanks!
Correct Answer by Stephen Rodriguez about 8 years 4 days ago
take a look at the link below. The one you want is, MS PEAP w/IAS, it has a pretty detailed walk through on configuring the IAS and an AP.
http://www.dweezlenation.com/
HTH,
Steve
Overall Rating: 5 (1 ratings)
Fernando Sacris... Fri, 01/31/2014 - 03:45
Hello adcorbett,
I'm having the same issue. The link that Stephen provided is broken. Do you remember how you configured the IAS and the AP?
Thanks in advance
Nando
Scott Fella Fri, 01/31/2014 - 05:06
Fernando,
Take a look at the doc because another bug part of this the the radius configuration and the certificate which is required on the radius server.
What I have done in the past is look at one example and search for others so you can get a good comparison if what you need to do. You can find links to doc and videos if you want to see how IAS should be setup.
Here is another example but with NPS which is similar
http://networklessons.com/wireless/peap-and-eap-tls-on-server-2008-and-c...
