WCS and WiSM upgrade order?
Jan 20th, 2009
I am getting ready to upgrade all or our WiSM's and the WCS. Currently running 4.2.81 WCS and 4.2.112 WiSM.
My question is, is there a preferred order as to which to upgrade first, the WiSM or the WCS?
Seth
sschmidt Tue, 01/20/2009 - 10:03
Upgrade the WCS first but make sure that the version on the WISM is supported by the code you upgrade WCS to.
srosenthal Tue, 01/27/2009 - 08:22
Do I need to shut down the WCS application before I start the upgrade? The documentation does not say to shut it down before upgrading.
Seth
sschmidt Tue, 01/27/2009 - 08:34
I would recommend the manual upgrade procedure from the documentation. This will uninstall the application so it will be shut down. The automatic upgrade can be problematic.
Trending Topics - Security & Network
