vtp version.
Answered Question
Jan 20th, 2009
hi Guys, i have two cisco 3560 switches.
but both shows VTP version two information differently, are there any actual difference in it?
sh vtp status
VTP Version : 2
sh vtp status
VTP Version : running VTP2
please help.
Correct Answer by MUHAMMAD SHAHEEN about 8 years 1 month ago
Hi Muhammad,
the ouput you have pasted does not mean it is running VTP version 2.
when you issue command vtp staus, pay attention to 8th line where it says VTP V2 mode, if it is enabled then this switch is running version 2 otherwise it is running version 1 but switch is capable to run version 2.
Here I paste the full output from one of the switch
Switch013#sh vtp status
VTP Version : 2
Configuration Revision : 7
Maximum VLANs supported locally : 1005
Number of existing VLANs : 8
VTP Operating Mode : Server
VTP Domain Name : Marketing
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x2B 0xC9 0xB0 0xB4 0x75 0xFA 0x62 0x67
Configuration last modified by 192.168.1.2 at 12-17-06 19:43:01
Local updater ID is 192.168.1.8 on interface Vl1 (lowest numbered VLAN interface
found)
I know it is little confusing, I have not seen anyone using VTP version 2, it is only needed in some special cases.
Hope this Helps....
Shaheen
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 01/20/2009 - 11:15
Hello Muhammad,
no difference they are both running VTP version 2
Sometimes some show output change their formats with different IOS versions and we need to adapt.
Hope to help
Giuseppe
sharma16031981 Tue, 01/20/2009 - 19:59
The first output shows this switch supports version 2 but it is not enabled on this switch
second output says this switch is enabled with vtp version 2.
run command vtp version 2 on first switch then see the changes.
Hemant Sharma
ahmad82pkn Wed, 01/21/2009 - 02:44
I heard VTP Version 1 and 2 are not compatible.
But when i changed my switch to VTP 1 then it got vlan updates from vtp2 server, why so?
Output of my VTP server
sh vtp status
VTP Version : 2
Output of my VTP Client
sh vtp status
VTP Version running VTP1 (VTP2 capable)
Correct Answer
MUHAMMAD SHAHEEN Wed, 01/21/2009 - 03:00
Hi Muhammad,
VTP Version : 2
found)
Hope this Helps....
Shaheen
