IPCC 4.0(5a)SR2 ports show IP address of CM instead of IPCC
Jan 20th, 2009
We are doing a new installation of IPCC 4.0(5a)SR2 with CM 4.1(3)SR6. IPCC ports are showing registered, but in the column where the IP Address of the IPCC server should be, it shows the CM address instead.
Chad Stachowicz Wed, 01/28/2009 - 15:21
  • Silver, 250 points or more
Well oddly enough the CTI Ports are actually localled locally so this would be expected. You should see the CUCM that is first in the CCM Group that the device pool of the CTI Port is referencing.
HTH,
Chad
kdunning Thu, 01/29/2009 - 03:52
Thanks Chad. We looked at older version of CM and IPCC and that is the case. IPCC V5 and CUCM 6 show the ip address of the IPCC server in the "ip address" field ....and that is what threw us initially. Thanks for replying.
