Jon Marshall Tue, 01/20/2009 - 14:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mike
To be honest off the top of my head i'm not sure but i have just tested on a 3550 as this is the only switch i have access to and
1) all the vlan interfaces use the same mac-address
2) all the physical ports have different mac-addresses
Simplest way to check, assuming you have access to 4500 is "sh interface"
Jon
burleyman Tue, 01/20/2009 - 14:37
  • Blue, 1500 points or more
Thanks.....So each physical port has its own MAC-Address.....do you know what command I can use to get those addresses using CATOS..... show port ???
Mike
Jon Marshall Tue, 01/20/2009 - 14:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Mike
"So each physical port has its own MAC-Address" - well it does on a 3550.
Try "sh port mac-address" on your switch.
Jon
burleyman Tue, 01/20/2009 - 14:52
Nope that is not an option.
4506 (enable) show port ?
auxiliaryvlan Show port auxiliary vlan information
cdp Show port CDP information
capabilities Show port capabilities
channel Show port channel information
counters Show port counters
debounce Show port link debounce timer
dot1x Show port dot1x information
errdisable-timeout Show port errdisable-timeout information
flowcontrol Show port traffic flowcontrol
ifindex Show port IfIndex information
inlinepower Show inline power for port(s)
lacp-channel Show LACP channel info by physical port
mac Show port MAC counters
negotiation Show port negotiation
protocol Show port protocol membership
security Show port security information
spantree Show port spantree information
status Show port status
trap Show port trap information
trunk Show port trunk information
unicast-flood Show port flooding
vtp Show port vtp status
Module number
Module number and Port number(s)
| Output modifiers
Mike
Jon Marshall Tue, 01/20/2009 - 14:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Mike
Sorry, took that from a 6500 command reference. What version of CatOS are you running on the the 4500 ?
Jon
burleyman Wed, 01/21/2009 - 05:07
Sorry for the delay in getting back to you...and thanks for your help.
I am running cat4000-k8.8-1-1.bin
I have been trying to find a command that would yeild that information so any help would be great.
Mike
burleyman Wed, 01/21/2009 - 05:18
I found it....
When you do a show mod it gives the information as follows
Mod MAC-Address(es) Hw Fw Sw
1 00-0e-38-8c-0b-40 to 00-0e-38-8c-0b-7f 6.0 6.1(5) 8.1(1)
2 00-0d-29-db-d1-a0 to 00-0d-29-db-d1-cf 1.1
3 00-02-fd-55-a7-20 to 00-02-fd-55-a7-4f 2.3
4 00-07-eb-a1-1c-30 to 00-07-eb-a1-1c-5f 3.0
5 00-b0-64-64-f0-60 to 00-b0-64-64-f0-8f 2.3
I can then get the info from that.
Mike
