Error when configuring SPAN to capture trunk port data with 802.1q tag
Answered Question
Jan 20th, 2009
Hello everybody,
When I configure SPAN on my 3750 switch, it gives me this error:
% Warning: One or more specified dest port does not support requested encapsulation.
The command I use to configure SPAN is:
(config)#monitor session 1 destination interface Fa1/0/24 encapsulation dot1q
I am using WireShark as the packet sniffer and I have configured my Ether Card on my PC to accept vlan tags however I still can't see the tags from the captured data...
I also tried to configure f1/0/24 as a trunk port but I still get the same error... I will very much appreciate any help or advice! Thanks!
Difan
Correct Answer by amikat about 8 years 1 month ago
Your command should read as:
monitor session 1 destination interface Fa1/0/24 encapsulation replicate,
as documented e.g. at:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/command/reference/cli1.html#wp9700521,
please see the Usage Guidelines part,
Best regards,
Antonin
Overall Rating: 5 (1 ratings)
