X25 Call , then file transfer
Jan 20th, 2009
I have an x25 call established between two peers through PAD over XOT. Assuming that i would want a packet transfer to be exchanged between both these peers (two end hosts connected to routers). Can i achieve this through regular ftp?
Thanks!
pauloroque Tue, 01/20/2009 - 17:54
Hello echelon,
Maybe what you need is X.25 and TCP/IP combination. I don't know if you are already using it. But, you can use the x25 link to pass your ftp traffic. Try this.
---R1
int s0
enc x25
x25 address 123456
x25 map ip 10.10.10.2 654321
ip address 10.10.10.1 255.255.255.252
ip route R2-SUBNET 10.10.10.2
---R2
int s0
enc x25
x25 address 654321
x25 map ip 10.10.10.1 123456
ip address 10.10.10.2 255.255.255.252
ip route R1-SUBNET 10.10.10.1
echelon360 Tue, 01/20/2009 - 19:38
thank you for replying!
I have attached a diagram of what i'm trying to achieve.
Essentially, i would like to have X25 calls generated between WAN POP A and WAN POP B. Once that is verified working. I would like to have WAN POP B migrate to Core 2. This will help me validate impacts on X25 during migration.
I was hoping to accomplish this by first,setting up an FTP transfer between both X25 PEERs and have that running. Once that is active, i will initiate the migration.
pauloroque Wed, 01/21/2009 - 05:58
Hi echelon,
I didn't understand the relation between the FTP and the X25 migratration. Can you provide more details?
PRoque
echelon360 Wed, 01/21/2009 - 14:12
thank you for taking the time to reply.
What i was hoping to achieve was
1) ensure an x25 call is active between both peers (i.e WAN POP A and B)
2) Ensure that there is packet transfer between both peers.
3) initiate the migration at the core end to see the effects it has on the x25 call/packet transfer
I will have two linux hosts plugged in at the endpoints of both the WAN POP Routers to ensure the packet transfer over X25.
I will have to run the same test again but this time, over an asynchronous serial interface and evaluate the impacts.
Any thoughts on this pls?
