About 802.1x port authentication using TACACS+
Jan 20th, 2009
I have some question. Please help me. Thanks.
Question1. May I use that 802.1x port authentication using TACACS+
Question2. Is it true? TACACS+ will not work with 802.1x because EAP is not supported in TACACS+, and there are no plans to get EAP over TACACS+.
Any help would be greatly appreciated.
connect101 Tue, 01/20/2009 - 22:04
- If you want to use 802.1x port authentication, it is better to use radius protocol because Tacacs+ doesn't support EAP.
- The command line when you use radius protocol is the same as the tacacs+ protocol
Guesttw123 Tue, 01/20/2009 - 23:51
Thanks to you.
Where to find the documents about Tacacs+ doesn't support EAP?
I cast more time and I cannot find the documents.
Please help me....
jafrazie Tue, 01/20/2009 - 23:56
There's nothing technically precluding this, although RADIUS is typically preferred by most.
Guesttw123 Wed, 01/21/2009 - 00:22
If There's nothing technically precluding this.
So I can do it that 802.1x port authentication using TACACS+?
If it is true, how to do it?
