"input packets with dribble condition detected" ??
Answered Question
Jan 20th, 2009
I do'nt know exact meaning of the
"input packets with dribble condition detected" in the output of show int fa1/0
also can't find the relative information about this error counter in cisco.com
what is the exact meaning??
Correct Answer by marikakis about 7 years 11 months ago
http://www.commsplace.com/Knowledge/ITcs/html/tutorials/applications/ethernet_basics.htm
"The InterPacket Gap (IPG) is the fixed time gap between Ethernet Frames."..."the maximum 802.3 frame size is 1518 bytes"..."A frame that is defined as a 'dribble' is one that is greater than 1518 bytes but can still be processed. This could point to a problem where the IPG is too small or non-existent such that two frames join together."
In ethernet controller/tranceiver specifications, dribble error is said to mean that "packet did not end on a byteboundary" or "non-integer number of bytes in packet". Now, the ethernet controller I looked up (http://www.bitsavers.org/pdf/3Com/Etherbox_Sep83.pdf) has receive buffers to put packets received from wire. Each receive buffer has a header part with information about the frame received (besides the actual contents of the frame received). One of the bits of the receive buffer header says whether a dribble error occured for the frame, hence the term "dribble bit error".
Kind Regards,
M.
Overall Rating: 5 (1 ratings)
Sanghee Han Tue, 01/20/2009 - 22:10
Thanks for your help.
I read the linked document.
but don't understand yet.
[Description]
Gives the dribble bit error, which indicates that a frame is slightly too long.
could you give me some explanation
=> what is the dribble bit error?
=> "a frame is slightly too long"
that means it's size is longer than what?
received frame?
Correct Answer
marikakis Wed, 01/21/2009 - 01:31
Kind Regards,
M.
Sanghee Han Wed, 01/21/2009 - 15:28
Now, I know about this error counter.
Thanks very much again.
Kind Regards,
SangHee.
