Syed Iftekhar Ahmed Wed, 01/21/2009 - 07:46
  • Blue, 1500 points or more
If you are running radius then use probe type radius, for tacacs You can set up a Layer 4 keepalive that opens a socket connection on the port to check if it is opened
probe radius RADIUS
interval 15
passdetect interval 60
credentials
probe tcp TACACS
port 49
interval 15
Syed Iftekhar Ahmed
