IPSec VPN Between two 880 3G Enabled Routers
Answered Question
Jan 20th, 2009
Correct Answer by patrickvanham about 8 years 3 months ago
You would need to set up a tunnel between the points, and for that you need the IP addresses. Normally this would be done with fixed addresses, but it may be possible using the hostname of the remote node, if that is fixed. If the name is based on the IP address, which is not unusual, you'd need to contact your provider for a fixed IP address.
It is also possible the provider has disabled intermobile traffic, in that case they cannot directly communicate if in the same APN. Another issue is that they may not allow tunneling unless on a different contract.
What may be best for you is to ask the provider to use a specific APN for machine to machine, as those often allow intermobile traffic, are transparent and are likely to allow fixed addresses.
Overall Rating: 4 (1 ratings)
Correct Answer
patrickvanham Wed, 01/21/2009 - 00:58
sauravcgc Wed, 01/21/2009 - 01:13
Hi Pat
Thanks for your reply. if i get the APN from the sp is it possible.
As i was referring a document which says 3G can used for backup and dyanic ip can be used like dialling configuration.
Thats why i am bit confused.
Saurav
patrickvanham Wed, 01/21/2009 - 04:38
3G is not much different from any other data connection with regards to setting up a tunnel. There are some specifics you need to set up for it to connect to the 3G network itself.
But if you want the two routers to connect to each other with IPsec tunneling they'd need either fixed IP addresses or fixed hostnames which can be resolved to the correct IP. Further, the APN has to allow intermobile traffic and it should preferably be transparent, but allowing IPSec over the APN would work fine as well. Providers generally have a specific APN that fulfill these contitions as machine to machine communications generally require this. The provider should be able to provide you with SIM cards that are provisioned for such an APN.
sauravcgc Wed, 01/21/2009 - 04:45
Hi Pat
Thanks for your suggestion. Now i it's clear.
I will check with SP.
Saurav
