external aerial setup
Jan 21st, 2009
Hi all
I have a 1240 access point with an aerial plugged into the right bnc connector, the aerial is one of the omni directional tube devices that hangs off the ceiling.
My question is, how should this be set up on the ap, does it need to be in diversity mode or not as its only plugged into one side ?
please help
Carl
Rob Huffman Wed, 01/21/2009 - 05:43
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Carl,
Diversity mode is only used with "two" Antennas. With one Antenna just use the Right hand "Primary" connector.
Hope this helps!
Rob
Rob Huffman Thu, 01/22/2009 - 07:04
  • Hall of Fame,
    Founding Member
Hi Carl,
Yes, this should be changed when only one antenna is used :)
Here are the commands to reset the Antenna settings to default,diversity (left-right) etc;
antenna
Use the antenna configuration interface command to configure the radio receive or transmit antenna settings. Use the no form of this command to reset the receive antenna to defaults.
[no] antenna {receive | transmit} {diversity | left | right}
Syntax Description
receive
Specifies the antenna that the access uses to receive radio signals
transmit
Specifies the antenna that the access uses to transmit radio signals
diversity
Specifies the antenna with the best signal
left
Specifies the left antenna
right
Specifies the right antenna
Defaults
The default antenna configuration is diversity
Examples
This example shows how to specify the right receive antenna option:
AP(config-if)# antenna receive right
Hope this helps!
Rob
srosenthal Tue, 01/27/2009 - 08:48
If you are using the omni that is designed to hang down from a ceiling, then you are using the wrong antenna for outside. That antenna can get water inside and cause you problems. You need to use the omni that is designed to be installed outside. It has the cable coming straight out of the bottom of the antenna. If yours has the cable coming out of the side of the aluminum then it is the wrong one for outdoor.
AIR-ANT2506 is for outdoor.
AIR-ANT1728 is for indoor.
Seth
Leo Laohoo Tue, 01/27/2009 - 13:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Here are some links regarding Cisco wireless antennaes:
1. Cisco Aironet Antennas and Accessories Reference Guide
www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
2. Cisco Aironet 2.4 GHz and 5 GHz Antennas and Accessories
www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008022b11b.html
Does this info help?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
