CRS HA failed to take call during failover
Jan 21st, 2009
Hi, I have a problem with CRS 5.0.2, during failover route point can't be triggered however it is showing registered with the primary CRS sever ip address and logically I am expecting it's registered with the backup crs server ip address. Agents are successfully re-login to backup CRS server. Cti ports from primary crs unregistered and cti ports from backup crs registered.
appreciate any replies, thanks
yusman_t Mon, 02/02/2009 - 16:24
The problem is the replication was not working properly, TAC solution: break the cluster and "SQL network utility" and put the "Named Pipes" on top of the list and re-join the cluster
