Operational temperature of outdoor APs
Jan 21st, 2009
Good Morning!
I wish to ask you some questions about the title above. More specificately:
- which is the maximum temperature of the air that can support the operational temperature indicated? For example, if the APs are sited in a desert or in a zone with high temperature and mmany hours of solar exposition which are the limit conditions of working? I have to deploy a wireless solution on railway enviroment and i will have to install some APs on open air in hard enviromental conditions (in that country the temperature can join the 40-45°C).
Anyway, can you suggest the best way or any "tip" to let the correct working of APs?
Many thank in advance
Best regards
rob.huffman Wed, 01/21/2009 - 05:41
Hi Alberto,
Something like the 1300 Series seems like a good fit;
Cisco Aironet 1300 Series Outdoor Access Point/Bridge
Operational Temperature
-22º to +131ºF (-30º to +55ºC)
Or a 1242 with NEMA enclosure;
Cisco Aironet 1240AG Series 802.11A/B/G Access Point
Rugged Metal Housing
Metal case and rugged features support deployment in factories, warehouses, the outdoors **(NEMA enclosure required), and other industrial environments.
• Non-operating (storage) temperature: -40 to 185°F (-40 to 85°C)
• Operating temperature: -4 to 131°F (-20 to 55°C)
• Operating humidity: 10 to 90 percent (non-condensing)
Hope this helps!
ASF_SVI_ITE Thu, 01/22/2009 - 04:36
Thanks for your answer Rob. But I asked another thing, i've already seen all datasheets. Really I'm finding someone that really esperienced the working of the outdoor AP in those climatic conditions. Anyway the 55 °C what mean? With direct solar esposition? Which is the relative temperature of chassis to substain that temperature?
I hope to be explained
Best regards
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
