Native VLAN: (Dot1q trunk links)
Jan 21st, 2009
Switches in the network are using VLan:100 as the management VLAN, with a SVI configured on all switches.
VLAN:1 SVI is shutdown on all switches security)
Q. What native VLAN should I use for the dot1q trunk links? What is the advantage/disadvantage (Cisco best practice) for using VLAN:100 or the default VLan:1 as the native VLAN.
Please advice
### Switches ###
management interface VLAN:100
Core SW: 10.100.0.1/24
Edge SW1: 10.100.0.10/24
Edge SW2: 10.100.0.20/24
interface vlan 1
description "shutdown"
shutdown
interface vlan 100
description "MGMT"
ip address 10.100.....
vlan 100
name MGMT
### Option 1 ###
interface g0/1
switchport mode trunk
no shutdown
### option 2 ###
interface g0/1
switchport trunk native vlan 100
no shutdown
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 01/21/2009 - 05:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Colm
Cisco best practice is to use a completely separate vlan for the native vlan ie. the native vlan should not be
1) vlan 1
2) your management vlan
3) any vlan with end user devices in it
So create a new unused vlan (we used to use vlan 999 at my last place of work). Do not create a L3 SVI for it because it doesn't need one. And then configure this as the native vlan on your trunk links.
Jon
