We have a subscriber(5.1.3) running as a redundant node for failover. I would like to use 128 cfb streams or more on this node. There are no devices registered to this node during normal operation but it is running CCM. Is anyone doing something similiar?
we do not recommend going over 128 streams if CUCM service is running, if you do it we won't support the deployment for any issues on the SUB
java
if this helps, please rate
java
