Rob Huffman Wed, 01/21/2009 - 06:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jamie,
This support was not added until the release of CUCM 6.1(2);
TSP Vista Support
• TSP supports the Microsoft Vista operating system
• When you use the Vista operating system, be aware of the following issues:
- Ensure a first-time installation of the CiscoTSP and Cisco Unified Communication Manager
TSP Wave driver on a computer that is running the Vista operating system is performed as a
fresh install.
- If a secure connection to Cisco Unified Communication Manager is used, turn off the Windows
firewall.
- If the Cisco Unified Communication Manager TSP Wave driver is used for inbound audio
streaming, turn off the Windows firewall.
- If the Cisco Unified Communication Manager TSP Wave driver is used for audio streaming,
disable all other devices in the “Sound, video and game controllers” group.
New and Changed Information in Cisco Unified Communications Manager 6.1(2)
http://cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.pdf
Hope this helps!
Rob
jamieparr Wed, 01/21/2009 - 06:56
If I can get hold of an updated TSP for CUCM 6.1(2) will it be compatible with my 6.0? I tried one for 7.0 this was not compatible.
Rob Huffman Wed, 01/21/2009 - 07:01
  • Hall of Fame,
    Founding Member
Hi Jamie,
I don't believe so :( I think you would need to upgrade to CUCM 6.1(2) @ minimum.
Hope this helps!
Rob
