SHDSL configuration on 2800 Router
Jan 21st, 2009
I need 4 SDSL ports on the 2800 router. Is i have to buy 4 WIC-1SHDSL-V3 cards for that?
Secondly Can you please provide me the template configuration to configure the router for SDSL link?
What information i need to get from the ISP to setup this link?
your help will be highly appriciated.
Overall Rating: 4 (2 ratings)
Giuseppe Larosa Wed, 01/21/2009 - 08:42
  • Hall of Fame,
    Founding Member
Hello Tauseef,
1) yes you need 4 WIC
2) exact configuration varies an example can be
http://www.cisco.com/en/US/docs/routers/access/1800/1801/software/configuration/guide/pppoanat.html
3)
you need to ask the following information:
atm parameters: Vpi/Vci to be used these have values that vary from provider to provider so you need ask to yours
typical values are 0/35 or 8/35
type of service: PPPoA like in example above, PPPoE or IP over ATM this can include authentication data username. password and protocol (pap, chap, ms-chap)
Hope to help
Giuseppe
t4tauseef33 Sat, 01/24/2009 - 05:22
Thanks for your reply. Its really helpfull Can you please also help me how to bundle these 4 SDSL lines together. I want to use all of these 4 sdsl lines as one link. how the ISP provides the bonded service.
mszeftawy Tue, 01/27/2009 - 01:07
Since you have only 4 SDSL lines you can buy only 2 WIC's as the mentioned WIC supports 4-Wire mode. And you can arrange with your service provider to provision double speed links over 4-wire. Also it can work as separate 2wire lines over a single WIC
Regarding the bundling of the 4-links I think that you can use a tunnel interface between your router and service provider router but you should 1st check the service provider bundling policy.
t4tauseef33 Wed, 01/28/2009 - 07:35
By googling, i came to know that there are few methods of bonding
1) PPP Multilink
2) Static Routes load balancing
3) Tunnel interface
Is there any other way of bonding them together and which one is the best?
paolo bevilacqua Wed, 01/28/2009 - 09:24
  • Hall of Fame,
    Founding Member
Routing load balancing (doesn't need to be static) is ok in most situations. Note 3) requires 2)
mszeftawy Thu, 01/29/2009 - 00:29
If both the 4 links have the same BW then you can load balance over these links using static route also you have to inform your service provider to load balance the return traffic
And you can also create a tunnel interface that runs over the load balanced links, and that will act as a bundle for the 4 links and in case of adding any routes (Dynamic or static) you have to use the tunnel interface and that will handle the load sharing over the 4 links.
But before using the load balancing and bundling you have to enable ip cef and choose load sharing technique (per-packet or per-destination). And that depends on your traffic type.
MaseBarnes Thu, 01/29/2009 - 00:57
For bundling try this:
controller DSL 0/1/0
mode atm
line-term cpe
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex B
line-rate auto
no shut
controller DSL 0/2/0
mode atm
line-term cpe
line-rate auto
no shut
controller DSL 0/3/0
mode atm
line-term cpe
line-rate auto
no shut
interface Multilink1
ip address negotiated
load-interval 30
no cdp enable
ip nat outside
ppp ipcp dns request accept
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
service-policy output grommit
interface ATM0/1/0.1 point-to-point
pvc b-dsl1 1/XX
ubr 2304
encapsulation aal5snap
protocol ppp Virtual-Template1
interface ATM0/1/0.2 point-to-point
ip unnumbered loopback 0
pvc noc1 0/XX
ubr 32
oam-pvc manage 10
interface ATM0/2/0
no ip address
no atm ilmi-keepalive
no shut
interface ATM0/2/0.1 point-to-point
pvc b-dsl2 1/XX
ubr 2304
interface ATM0/2/0.2 point-to-point
pvc noc2 0/XX
ubr 32
oam-pvc manage 10
interface ATM0/3/0
no ip address
no shut
interface ATM0/3/0.1 point-to-point
pvc b-dsl3 1/XX
ubr 2304
interface ATM0/3/0.2 point-to-point
pvc noc3 0/XX
ubr 32
oam-pvc manage 10
interface Virtual-Template1
bandwidth 2300
no ip address
ppp pap sent-username login password password
ppp multilink
