CUCM upgrade Checksum
Answered Question
Jan 21st, 2009
I am trying to upgrade from 6.1.2 to 6.1.3.
After the file is installed, I get the warning to check the integrity of the file against the cisco web site. For some reason, I am unable to access the release notes for 6.1.3. Is there anywhere else to find this hash value?
Correct Answer by Rob Huffman about 8 years 6 months ago
Hi Robert,
Here you go :)
Use an md5sum utility to verify that the MD5 sum of the final file is correct.
417c262e5706103c4e75a825e1d5d902 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
http://www.cisco.com/web/software/282074295/24094/ciscocm-6-1-3.Readme.pdf
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 01/21/2009 - 07:17
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Robert,
Here you go :)
Hope this helps!
Rob
Rob Huffman Wed, 01/21/2009 - 07:28
  • Hall of Fame,
    Founding Member
Hi Robert,
You are most welcome! Best of luck with your upgrade.
Cheers!
Rob
