IPS Signature versions doesnt match from system info and dashboard
Jan 21st, 2009
Hi, I have a customer who has a IPS runing version 6.2(1)e3. after the last auto update, the sig version from the asdm system info shows 377, however from the IDM health dashboard, the sig version shows 373, I am wondering if someone can provide some suggests what might cause the problem, thanks in advance
Christopher Bell Tue, 01/27/2009 - 05:46
  • Bronze, 100 points or more
When this happened to me, I rebooted the sensor and fix it. If the IPS sensor is "inline", be sure you are in Auto bypass mode. Meaning - if the sensor fails, traffic is not halted.
Hope this helps.
applegreen Tue, 01/27/2009 - 09:56
Hi, I will let customer try. thanks a lot for the tip
