Access to hosts from outside
Answered Question
Jan 21st, 2009
I want to enable access to server on ip address: 192.168.100.30 on port 22 located in inside interface from internet (outside)
We have ASA 5520 Cisco Adaptive Security Appliance Software Version 8.0(2)
My config (only relevant lines):
interface GigabitEthernet0/0
nameif Outside
security-level 0
ip address 172.146.147.13 255.255.255.248 standby 172.146.147.12
interface GigabitEthernet0/1
nameif DMZ
security-level 50
ip address 172.146.147.1 255.255.255.248 standby 172.146.147.2
interface GigabitEthernet0/3
nameif Inside
security-level 100
ip address 192.168.200.3 255.255.255.0 standby 192.168.200.2
access-list Inside_access_in extended permit ip 192.168.100.30 any
access-list Inside_access_in extended deny ip any any
access-list Outside_access_in extended permit tcp any host 172.146.147.15 eq ssh
access-list Outside_access_in extended deny ip any any
global (Outside) 1 172.146.147.11 netmask 255.255.255.0
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 1 10.1.33.0 255.255.255.0
nat (Inside) 1 10.1.34.0 255.255.255.0
nat (Inside) 1 10.1.35.0 255.255.255.0
nat (Inside) 1 10.1.36.0 255.255.255.0
nat (Inside) 1 10.1.39.0 255.255.255.0
nat (Inside) 1 10.1.41.0 255.255.255.0
nat (Inside) 1 10.1.42.0 255.255.255.0
nat (Inside) 1 10.1.44.0 255.255.255.0
nat (Inside) 1 10.1.99.0 255.255.255.0
nat (Inside) 1 10.40.2.0 255.255.255.0
nat (Inside) 1 10.40.24.0 255.255.255.0
nat (Inside) 1 192.168.100.0 255.255.255.0
nat (Inside) 1 192.168.250.0 255.255.255.0
nat (Inside) 1 192.168.96.0 255.255.248.0
static (Inside,Outside) tcp 172.146.147.14 ssh 192.168.100.30 ssh netmask 255.255.255.255
access-group Outside_access_in in interface Outside
access-group DMZ_access_in in interface DMZ
access-group Inside_access_in in interface Inside
route Outside 0.0.0.0 0.0.0.0 172.146.147.14 1
route Inside 10.0.0.0 255.0.0.0 192.168.200.1 1
route Outside 172.16.101.72 255.255.255.252 195.146.147.14 1
route Inside 192.168.0.0 255.255.0.0 192.168.200.1 1
When i type telnet 172.146.147.15 22 from public internet i cant open port 22....so i dont know - is something missing or wrong?
Thanks.
Correct Answer by Tshi M about 8 years 2 months ago
below is your outside interface config
nameif Outside
security-level 0
you are using 255.255.255.248 as the subnet which makes 172.146.147.15 as your broadcast address. That being said, you won't be able to access it. You need to use a different address in that range. the available addresses are 172.146.147.9 to 172.146.147.14.
regards,
Overall Rating: 5 (1 ratings)
Mo'ath Al Rawashdeh Wed, 01/21/2009 - 07:58
  • Bronze, 100 points or more
"access-list Outside_access_in extended permit tcp any host 172.146.147.15 eq ssh"
"static (Inside,Outside) tcp 172.146.147.14 ssh 192.168.100.30 ssh netmask 255.255.255.255"
Unless this is a typo, the access-list has to be:
access-list Outside_access_in extended permit tcp any host 172.146.147.14 eq ssh (not 172.146.147.15)
lubosbella Wed, 01/21/2009 - 11:51
Sorry i copied bad line....
Right statements are:
static (Inside,Outside) tcp 172.146.147.15 ssh 192.168.100.30 ssh netmask 255.255.255.255
but this is not working ....
Any other suggestion?
Thank.
Tshi M Wed, 01/21/2009 - 12:12
  • Silver, 250 points or more
do you have logging enable? Using ASDM, you can trace the packet and see where the deny occurs.
lubosbella Wed, 01/21/2009 - 13:25
No logging is not enable for now....
Maybe can help this:
access-list Outside_access_in line 7 extended permit tcp any host 172.146.147.15 eq ssh (hitcnt=0) 0xb6f77e86
access-list Inside_access_in line 29 extended permit ip host 192.168.100.30 any (hitcnt=77) 0x4db26635
show xlate:
PAT Global 172.146.147.15(22) Local 192.168.100.30(22)
PAT Global 172.146.147.11(30) Local 192.168.100.30(123)
PAT Global 172.146.147.11(34204) Local 10.1.44.51(52658)
thank
Tshi M Wed, 01/21/2009 - 13:29
you are not hitting your PAT address. hit counts on 172.146.147.15 is zero.
regards,
Correct Answer
Tshi M Wed, 01/21/2009 - 13:46
nameif Outside
security-level 0
regards,
Tshi M Thu, 01/22/2009 - 04:45
I am glad to here!!
