Getting the error message while saving the configuration.
Jan 21st, 2009
We are getting the error message when we are trying to save the configuration.
% Error saving SNMP ifIndexes No space left on device
% Error saving SNMP ifIndexes No space left on device[OK]
Directory of flash:/
1 -rw- 9304844 <no date> c3660-i-mz.123-24.bin
33030140 bytes total (23725232 bytes free)
Giuseppe Larosa Wed, 01/21/2009 - 08:35
  • Hall of Fame,
    Founding Member
Hello Navinder,
the config file is saved in nvram:
do
dir nvram:
you have enabled snmp ifindex persist so the device is trying to save a table with the SNMP ifindexes to be used at next reload
verify if the nvram: is full
if so you should think of putting the configuration file on a tftp server
Hope to help
Giuseppe
