CUC 7x User Template
Jan 21st, 2009
How do I set Phone Password on the default user template (Voice Mail User Template). In Unity there is an option to set "Phone Password for new subscribers" on the Default Subscriber template. Where is this functionality in CUC 7x ?
Overall Rating: 2 (1 ratings)
Ginger Dillon Wed, 01/21/2009 - 08:56
Hi -
In the Unity Connection SA page, select the User template you want to work with. Go to Edit - Change password. Select Voice Mail password. Change the new password, confirm, and then Save. Any user created with this user template will get the same password. Make sure you also have the "Set for Self-enrollment at Next Login" checked on the User Template Basic page.
Ginger
CCSI_Instructor_2 Wed, 01/21/2009 - 09:18
I am using LDAP authentication; so pswd setting is greyed out. Users tried their AD passwords, but did not work. My workaround was to go to Bulk Edit Utility and set common pswd for all, but this is not best way. Looking for way to set on the template itself. thks
