Temporary Disable RA VPN tunnel groups
Jan 21st, 2009
We have numerous RA tunnel groups for vendors that do not always need access.
I want to keep the RA tunnel intact and enable/disable as needed.
What I have been doing is removing the PSK from the RA tunnel config.
You get a prompt:
"Without a PSK or Trustpoint configured, no tunnel can be established.
Do you still want to continue?"
My question is, is this a safe way to disable the tunnel?
According to the prompt, unless I input the PSK, there will be no tunnel established, but I want to know for sure that this is safe to do.
I have tried to access with a VPN client and a blank group password and cannot connect, but I want to make sure there is not something I am missing.
Assign a valid time range to the RA VPN.
time-range << some 3rd party>> 01 January 2009 end 23:59 31 January 2007
group-policy << some 3rd party>>
vpn-access-hours value << some 3rd party>>
Then the 3rd party can only log in during that time frame - when you don't want them to connect, just change the date/time.
