AP 1231G doesnt accept break sequence.
Jan 21st, 2009
Hi all,
I need urgent help. I need to boot our
AP to rommon, but It doesnt accept break sequence Ctrl + break. I use putty as connection client to console port of AP.
Any idea?
BR
jl
jeff.kish Wed, 01/21/2009 - 09:31
  • Silver, 250 points or more
If you're desperate, you can always delete/rename the IOS image in flash and reboot.
Otherwise, try a different terminal program, such as Hyperterminal or TeraTerm. Maybe it's just putty - I've seen some terminals have issues sending break commands.
johnleeee Thu, 01/22/2009 - 02:37
Hi Jeff,
problem is that AP doesnt accept break sequence when I unplug and plug AP. It boots normally further. But et the end of booting I cannot go to CLI when I press Enter. Thats the problem.
I tried other apps like Hyperterm, SecureCRT and so on, but without results.
Any idea?
BR
jl
jeff.kish Mon, 01/26/2009 - 07:41
Unfortunately I've never seen this particular issue. Have you opened a TAC case on this yet? If not I would do so and see what they suggest.
Scott Fella Mon, 01/26/2009 - 08:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I don't think you can do the break like a switch or router.... what exactly are you trying to fix? If its a firmware issue then do the following:
To recover this AP1200, I would do this:
1. Get an AP1200 image from CCO; use one of the following IOS versions:
12.3(7)JA4
12.3(JA2
12.3(JEA
2. Find a computer that you can play with, and put a known good TFTP server
on it. I like the current Solarwinds server; if you have your own
favorite, so much the better.
3. Put the new AP1200 image into the TFTP server's root direction; rename
it to "c1200-k9w7-tar.default".
3. Address this computer's LAN adapter with 10.0.0.2.
4. Put this computer and the AP1200 on the same LAN.
5. Perform the mode button recovery procedure.
If its a password reset then follow this link:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_password_recovery09186a00800949d0.shtml#resios
