Custom Softkey
benbollinger
Level 2
Level 2
I am trying to add a custom softkey to ccm4. I have the url that the button press would need to activate but i'm not sure where the file is to add the code to for the softkey. Is there a doc for this or does someone have any example? Also, is this different of available on ccm6?
Jaime Valencia
you need to get in touch with Cisco Developer support for that matter.
no version has the custom softkeys capabilites and there are no guides available on CCO
java
if this helps, please rate
java
I am with a Adv. IPT Partner, and we are looking for our next steps to begin this type of development. Can you point me in the right direction?
sure, info about developer program and contact can be found here:
Welcome to Cisco Developer Services Central!
http://www.cisco.com/en/US/products/svcs/ps3034/ps5408/ps5418/serv_home.html
java
java
