VRU 3.5 No. of executed steps: 1000 Exception
Jan 21st, 2009
Hi !
The CRA application aborted after some timeout.In log I found below error:
239976: Jan 21 18:33:11.318 IST %MIVR-APP_MGR-7-STEP_FAILURE:Failure to execute a step: Application=....
,Exception=com.cisco.wfframework.obj.WFMaxExecutedStepsExceededException: No. of executed steps: 1000
I changed wfengine.properties file in wfavvid folder property com.cisco.wfframework.engine.MAX_EXECUTED_STEPS from 1000 to 2000, restarted CM and IPIVR but get same error.
Is exist workaround?
Chris Deren Wed, 01/21/2009 - 12:42
Are any of your scripts that long? If not then you are most likely running into some infinite loop, I would analyze the log closer to determine which script is cuasing it and then review the script.
Chris
