01-21-2009 11:51 AM - edited 03-06-2019 03:34 AM
Hi every body!
I was just wondering which windows OS supports dot1p(cos values)
thanks a lot!
Solved! Go to Solution.
01-21-2009 11:56 AM
This maybe hardware dependent but on Windows XP you can enable 802.1p QoS but I am not sure how to assign the CoS value but apparently you cna enable 802.1p on Windows XP.
01-21-2009 11:56 AM
