Trying to install 2 - Aironet 1300 Bridges... major problems
Jan 21st, 2009
I set up both ends of this bridge (about 1 mile apart) and I get an association, so I think I'm golden... well, I haven't been able to get the web gui ping/link test to work at all across them, so I upgraded to the 12.4 IOS on the main site, then went to the far-end site to upgrade that one and now I can't even bring up the web gui... I can ping it from the CLI of the switch, but not from the laptop I have connected via CAT5 to the switch... any suggestions?
Did upgrading the IOS cause this somehow????
srosenthal Tue, 02/03/2009 - 08:00
Have you tried to telnet or console to the bridge and verify your configuration? You might need to write erase the config and re-configure the box. Can you post your configs?
Do you have clear line of site? Are you using the internal antenna model, or external antenna model?
Make sure that your config says: ip http server
Seth
jeff.kish Tue, 02/03/2009 - 08:51
  • Silver, 250 points or more
Being able to ping from the switch but not your laptop makes it sound like it does not have the proper default gateway. Try telnetting to the bridge from the switch.
