Static translations not working
Jan 21st, 2009
I have configured some static translations for my new ASA 5510 which is on our new internet ciruit. For some reason, I see hits on my acl but get no response from internal hosts. I get hits on my inbound acl but still no response on the other end. Anyone have any ideas to help me? I called cisco and according to TAC my configuration is correct. I'm not sure what to do.
Tshi M Wed, 01/21/2009 - 12:50
  • Silver, 250 points or more
do you mind posting the relevant config and also the sh xlate? Have you used ASDM to trace the packets?
chevymannie Wed, 01/21/2009 - 12:55
static (inside,outside) tcp 66.x.x.67 smtp 192.168.0.x smtp netmask 255.255.255.255
static (inside,outside) tcp 66.x.x.67 www 192.168.0.xwww netmask 255.255.255.255
static (inside,outside) tcp 66.x.x.67 https 192.168.0.x https netmask 255.255.255.255
static (dmz,outside) tcp 66.x.x.68 www 66.x.x.68 www netmask 255.255.255.255
static (dmz,outside) tcp 66.x.x.68 ftp 66.x.x.68 ftp netmask 255.255.255.255
static (inside,outside) tcp 192.168.0.x 3389 66.x.x.69 3389 netmask 255.255.255.255
global (outside) 1 interface
global (dmz) 1 interface
access-list inbound extended permit tcp any host 66.x.x.67 eq smtp
access-list inbound extended permit tcp any host 66.x.x.67 eq www
access-list inbound extended permit tcp any host 66.x.x.67 eq https
access-list inbound extended permit tcp any host 66.x.x.68 eq www
access-list inbound extended permit tcp any host 66.x.x.68 eq ftp
access-list inbound extended permit tcp any host 66.x.x.69 eq 3389
PAT Global 66.x.x.67(25) Local 192.168.0.x(25)
PAT Global 66.x.x.67(80) Local 192.168.0.x(80)
PAT Global 66.x.x.67(443) Local 192.168.0.x(443)
PAT Global 66.x.x.68(80) Local 66.x.x.68(80)
PAT Global 66.x.x.68(21) Local 66.x.x.68(21)
PAT Global 192.168.0.213(3389) Local 66.x.x.69(3389)
I'm not too concerned about the DMZ right now I'm just trying to get the rest working first.
Tshi M Wed, 01/21/2009 - 13:02
I will start by fixing your last static entry.
Tshi M Wed, 01/21/2009 - 13:07
I am going to assume that you have nat (inside) 1 configured as well?
Can you access the Internet from that ASA?
chevymannie Wed, 01/21/2009 - 13:10
Yes and the last static entry isn't a concern to me right now. The first few are.
Tshi M Wed, 01/21/2009 - 13:30
I surely understand your frustration. From what you posted, your config looks good to me as well. Is your inside switch using PBR? Could please post your sh access-list?
regards,
