01-21-2009 12:50 PM - edited 03-04-2019 12:55 AM
I am still learning some commands and what they do. Here is a confiruation on one of our routers. Can someone explain lin by line what they accomplish?
route-map p2p-weight permit 10
continue 20
set weight 4000
route-map p2p-weight permit 20
set metric 10
route-map mpls-weight permit 10
continue 20
set weight 6000
route-map mpls-weight permit 20
set metric 10
Mike
01-21-2009 01:29 PM
Hello Mike,
these two route-maps are thought to be used with BGP to manipulate some BGP attributes:
first route-map is made of two blocks or clauses 10 and 20.
first block set BGP weight to 4000 (default value is 0 for routes coming from other routers)
the continue 20 command is a sort of goto label that tells to go to block 20
so then block 20 is executed and the end result is that all routes have the weight set to 4000 and MED (BGP metric) set to 10 (here the default value is simply unset or is a copy of an IGP metric)
the same schema is applied to the second route-map
you can expect to see in BGP config lines like:
neigh x.x.x.x route-map p2p-weight in|out
Hope to help
Giuseppe
01-21-2009 01:37 PM
Mike
In addition to Giuseppe's post -
metric is used to influence incoming traffic from BGP neighbors so you are advertising this to EBGP peers.
weight is only local to the actual router.
So under your "router bgp
Jon
01-21-2009 01:47 PM
This is what I have...
router bgp 65014
bgp router-id 10.20.1.225
bgp log-neighbor-changes
neighbor 10.115.123.53 remote-as 65000
neighbor 206.115.123.53 remote-as 65000
maximum-paths 2
address-family ipv4
neighbor 10.115.123.53 activate
neighbor 10.115.123.53 soft-reconfiguration inbound
neighbor 10.115.123.53 route-map mpls-weight in
neighbor 206.115.123.53 activate
neighbor 206.115.123.53 soft-reconfiguration inbound
neighbor 206.115.123.53 distribute-list 10 out
neighbor 206.115.123.53 route-map mpls-weight in
maximum-paths 2
no auto-summary
no synchronization
network 10.20.1.0 mask 255.255.255.0
network 10.115.123.52 mask 255.255.255.252
network 206.115.123.52 mask 255.255.255.252
aggregate-address 10.20.0.0 255.255.0.0 summary-only
exit-address-family
address-family nsap
maximum-paths 2
no synchronization
exit-address-family
Mike
01-21-2009 02:15 PM
Hello Mike,
the same route-map mpls-weight is applied to both neighbors in address-family ipv4 (unicast)
and also there is maximum-paths 2
this router is going to install in routing table two paths for each destination if the two neighbors provide the same set of routes (or at least for routes in common)
you can check with sh ip bgp X and sh ip route X
where X is one prefix learned in BGP.
Hope to help
Giuseppe
01-22-2009 04:46 AM
So who ever put this in are they tring to do load balancing? or something else? What would happen if they were removed?
Thanks for your help,
Mike
01-22-2009 09:09 AM
Hello Mike,
yes the idea is to implement load-balancing between these two neighbors preferring them to other (if other ones exist)
If there no other neighbors if you remove the neigh x.x.x.x route-map mpls-weight in there will be no change on the local router.
the setting of MED (metric) could however have an impact if there are other eBGP neighbors on other routers of this site/domain.
Hope to help
Giuseppe
