ltd Wed, 01/21/2009 - 14:05
Jim,
according to the datasheet for that NIC (http://h18004.www1.hp.com/products/servers/networking/nc510f/index.html), it says that it is "10GBASE-SR fiber optic".
The "SR" (short range) part here is the important part. The specifications for SR are standardized - so anything that is "SR" will interoperate.
so: the Cisco "SR" part will work fin, the "LRM" won't, as LRM is a different standard.
SR optics use multimode fiber - so you'll need that.
from memory, an Cisco X2 optical module has SC connectors, the HP NIC looks to be LC connectors, so you'll need a multimode patch cable that is LC-SC - again - something that is fairly standard.
jdw28 Wed, 01/21/2009 - 14:10
Thanks for the quick reply.
I agree with you they should work. However, do you know anyone who has tried such setup, which will cost us $4000 for a single connection? Just want to protect our investment.
Thanks.
-Jim
ltd Wed, 01/21/2009 - 14:14
I don't know of any specific instance of that NIC as such, however both HP & Cisco are big companies, we are both committed to standards, provided both actually do meet the spec (and I have no reason to think that they wouldn't), then it will work fine.
You need to make sure you stay within the bounds of what fiber infrastructure (MM) and distances that SR optics allow - but provided you are within that, if there was any issue of it not working, you'd have either/both Cisco/HP support on the hook to make it work for you. :)
I have many servers connected in my lab using 10GbE NICs. Not that particular NIC, but plenty of them with SR optics.
cheers.
jdw28 Wed, 01/21/2009 - 14:18
We are within the SR distance limit. We will give it a try. Thanks for the help.
