CME very simple design question
Jan 21st, 2009
I am currently working on a call manager express 4.2 setup.
My client has emailed me a requirement for his site's deployment.
Here is his requirement:
When customer calls 5545-8220, 5545-8206 rings.
If 8206 is busy then, 8205 rings.
If 8205 is also busy, 8204 rings.
if 8204 is also busy, send back busy tone to caller.
When customer calls 5545-8001, 5545-8205 rings.
8206 rings 4th, 8204 rings 5th.....
Those are two senerios that he mentioned. Now, my question is, do i create some sort of hunt grou, if so, how?
or do i just create some type of call forward all set? Please help.
paolo bevilacqua Wed, 01/21/2009 - 14:25
  • Hall of Fame,
    Founding Member
Ephone-hunt xxx
pilot 8001
list ...
All these things are explained in "system administrator guide".
Jaime Valencia Wed, 01/21/2009 - 15:00
  • Cisco Employee,
  • Hall of Fame,
    2011
haha there is always a way to get around =). i cannot open a case for you but i can certainly help here:
on this link you can find the info on that
Configuring Call-Coverage Features
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html
on the bottom there are examples
java
if this helps, please rate
shirwaziri1_2 Fri, 01/23/2009 - 20:12
Nice, very nice. Thanks for replying and sending me the link. Below once again are my two senerios and below that are the configuration for each senerio. I put in quotes my final questions to get my config setup correctly. Please advise on what I should do next to solve my config.
1. When customer calls 5545-8001, 5545-8205 rings.
ephone-hunt 1 sequential
pilot 8001
list 8205, 8206, 8204
final ?
max-timeout 10
timeout 20, 20, 20
(How do i get the hunt group to dial 8205 and then on the 4th ring go to 8206, and then on the 5th ring go to 8204. Also, they want it to ring busy after 8204, what do i do for it to ring busy after the final hunt.)
2. When customer calls 5545-8220, 5545-8206 rings.
ephone-hunt 2 sequential
pilot 8210
list 8250, 8251, 8253, 8320
final ?
( this one is pretty straight forward, but how do I get it to dial busy after the final hunt list. I guess i could just put any number their that goes no where, but is their a better method)
shirwaziri1_2 Mon, 01/26/2009 - 11:13
Thank you very much. I think for this setup, i will keep it simple. But I will say, i am keeping your little script for future use.
I need to finalize my hunt group settings. Here are my final questons. It is in regards to the following:
pilot 8210
list 8251, 8250, 8253
final 9999
Question 1. 8250 and 8253 need to light up and not ring in the hunt group? Is this possible, if so, how?
Question 2. I still need to figure out once the final Hunt number in the Group is not picking up or is busy, we want the customer to get Busy tones. How do I accomplish this?
