Marking all inbound packets to DSCP=EF
Jan 21st, 2009
I need to mark all the traffic arriving at a particular switcg port with a dscp value of EF.
I have the following configuration but as best I can tell its not working. If I run show access list the hit counter never increments but when I sniff on the port I am applying the service-map to I see a mountain of UDP traffic.
Any thoughts would be helpful - thanks.
access-list 105 permit udp host 10.100.120.120 any
class-map match-all VOIP
match access-group 105
policy-map SETDSCP
class VOIP
set dscp ef
interface GigabitEthernet7/48
switchport
switchport access vlan 200
switchport mode access
no ip address
speed 1000
duplex full
mls qos statistics-export
mls qos trust cos
spanning-tree portfast
service-policy input SETDSCP
Jon Marshall Wed, 01/21/2009 - 15:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Which switch type are you using ?
Jon
Jon Marshall Wed, 01/21/2009 - 15:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Do you want to mark ALL traffic as EF ?
If so you should remove the "mls qos trust cos" statement because you don't want to trust any Cos values received you simply want to set the value to EF.
Jon
neil_titchener Wed, 01/21/2009 - 17:55
Run a span session on the vlan interface and filter it to only display the IP address in question. That will show you if the traffic is being marked.
It's better to span the VL interface and not the physical port as I think the traffic coppied to the span session is taken before any manipulation, i.e. before the DSCP markings would be added.
Have you enabled QoS globally?
