BLF
Jan 21st, 2009
Hi there
My system versions
SPA 400 1.1.2.2
SPA 9000 6.1.5
SPA 942 6.1.3(a
SPA 922 6.1.3(a)
Just a question on BLF
I try to monitor blf sd & cp using wizard, it works byt what I notice is that if I have same number monitored by more than one phone it is very unreliable.
Example of my setup
ext 101 spa942
ext 100 spa 942
ext 102 spa 941
ext 106 spa941
ext 101 config
line 2 = ext 100 blf sd cp
line 3 = ext 102 blf sd cp
line 4 = ext 106 blf sd cp
ext 100 config
line 2 = ext 101 blf sd cp
The test I am doing is to rapid fire call other blf keys by pressing one at a time and hanging up. The phones I am trying to call will always ring, but it is very hit or miss as to wether the line key will flash red. In relation to blf, sometimes it works, sometimes it doesnt, and occaisionally it seems to lockup the key IE keeps flashing, and cant use that button. Have to reset the phone to clear this.
Based on what I can see here, this is unusable and does not work properly.
Am I missing somethingn here?
Alberto Montilla Thu, 01/22/2009 - 01:24
  • Cisco Employee,
Hi Terry;
Thanks for the details.
Currently an extension can be monitored by one station only (SPA932 or a phone line key). You can use Call Pickup or Speed dial for an extension in many stations, but not BLF. That's the reason of your system's BLF unstable behavior.
terry_king Thu, 01/22/2009 - 01:41
Thanks Alberto, I suspected tbat was the case. Thanks for the reply
mattiasreichel Tue, 03/10/2009 - 05:31
Hi, I also have this problem.
I've got four SPA962 with attached SPA932 that all need to monitor each others line status.
My hair has gone gray trying to get this to work and I could not find any information in the SPA932 documentation about this limitation.
The documentation for SPA962 mentions it though, so I thought it was a limitation only for SPA962 that could be remedied with an attached SPA932.
When you say "currently", I take it that this will be fixed in the future?
Is there a roadmap for when this will fixed and when an firmware upgrade will be released?
Alberto Montilla Tue, 03/10/2009 - 08:26
  • Cisco Employee,
Dear Sir;
This is a design limitation for the SPA9000 (not the phones), there is no short term plans to enhance SPA9000 to support multiple supervisors.
Alberto
mattiasreichel Tue, 03/10/2009 - 09:05
Ok, then it is pretty useless to me :(
Thanks for the info!
By the way, that's a strange design limitation (just my opinion, of course). :)
/Mattias
osaid-suliebi Sat, 01/29/2011 - 23:06
Dear sir,
I have 2 problems in SPA932(speed dail,BLF) attached with linksys ip phone SPA962;the first one is:after i upgrade SPA962 to 6.1.3a and set the password on phone i can not make a calls from spa962 if ip phone is locked(this is good) but i can made a calls from SPA932 although ip phone SPA962 is locked (how can i prevent making a calls from spa932 if i locked my spa962 by set password??)
the second problem is:if i made call using speed dial buttons on spa932 and get handset by my hand,the headset turn on (the voice still in head set not to handset)
thank you
Osaid
Related Content
