Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929625members
1244377discussions
Community Activity
AP issue
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS  Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
Cisco anyconnect browser ERR_SSL_Protocol_ERROR
Good day to everyone.I have two Cisco ASA running on FPR2130 assembled into a balancing group, for example:vpn-gw1.example.comvpn-gw2.example.comgeneral address vpn.example.com.Firmware version 9.18.3.56Anyconnect 4.10.07062At the moment, all our emp...
ATA 192 not registering with Webex Calling
I have an ATA192-3PW-K9 V04 and cannot get it to register. I have it flashed to the latest firmware. I created the device as a workspace with it's mac address and DID/extension in Webex. When I factory reset the device, all I'm doing is going to voic...
VPN Tunnel connecting at a unconfigured setting - Phase 1 Timer
OK, so I've got a set of ASA's and we are migrating them to Firepowers, and all seems ok. In the past we have noticed that for some reason on the ASA's, no matter what you specify as the parameters for phase 1, the rekey timer always connects at 3600...
Screenshot 2024-04-25 142720.png Screenshot 2024-04-25 142752.png StephenCarter_0-1714052852588.png
Intermittent Static noise on phones
We are a healthcare facility.  For past several months we have had several complaints from users that calls are often full of static.   We are running CUCM 12.5(1)SU8 and the phones are primarily 8811 running current firmware.   We have replaced phon...
NTP and Syslog packets with specific IP Address
Hi All,I have a couple of C9300 L3 switches that are connecting to an ASA firewall. The NTP and the syslog server for the switches are located behind a firewall.When one of the switches request/send packets the gateway IP is the source address on the...
Ranjita by Level 1
  • 117 Views
  • 9 replies
How to fix cast iron without welding?
Fixing cast iron without welding can be effectively accomplished through the use of a metal epoxy. This method involves cleaning the broken pieces thoroughly to remove any dirt, grease or rust. Once clean, apply a high-quality metal epoxy over the br...
cannot get to privileged enable mode via console
After searching through other posts, my config seems OK but still strange behaviourasa 9.20 running on FPWR chasisI cannot get in enabled mode when connecting to ASA via console.It used to work but stopped after I played (disable and restore) with aa...
kewwa by Level 1
  • 144 Views
  • 6 replies
Cisco 2960S not pinging, but has DHCP address
Hi,I am trying to set up an SSH connection to my switch, but right now there is some lower level problem. I have set up my FastEthernet0 interface to ip address dhcp and the command show interfaces FastEthernet0 shows the correct address. Even if I t...
limex by Level 1
  • 19 Views
  • 1 replies
FTD re-register to FMC chassis mode
Deployed a 3100 in chassis mode to the FMC a few days ago. All went to plan.Determined we needed to change the IP so decided just to delete the device from FMC and re-provision it.On the FTD via local-mgmt did a erase configuration. The device wiped ...
glsparks by Level 1
  • 4 Views
  • 0 replies
