blocking www.blocksite.com
Jan 21st, 2009
Hello
i'm asked by our Manager to block specific site let us asume http://www.block.com, as normal i logged into the router and start with these 3 lines
access-list 110 deny tcp any host http://www.block.com eq www
(for other site to be accessable)
access-list 110 permit tcp any any eq www
in the interface that facing the ISP
ip access-group 110 out
it's successfully block http://www.block.com and accordingly all other sites in the web.
what could be wrong, please i need advice.
thank you.
aneesh.ts Wed, 01/21/2009 - 22:17
i think you should mention permit ip any any as the second line insted of tcp any any
access-list 110 permit ip any any
Because the command you gave will only permit TCP traffic, but block rest.
try and lemme know whether it worked.
aneesh.ts Wed, 01/21/2009 - 22:23
Also try the ip address insted of the URL.
Insted of this try
access-list 110 deny tcp any host eq www
do an nslookup http://www.block.com in your command prompt to resolve the URL. Since router would not be able to resolve your DNS name to ip address(Not sure). Kindly find the nslookup am getting from my command prompt.
P:\>nslookup http://www.block.com
Server:
Address: 192.168.134.39
DNS request timed out.
timeout was 2 seconds.
*** Request to timed-out
P:\>nslookup block.com
Server:
Non-authoritative answer:
Address: 65.220.68.100
I am unable to resolve http://www.block.com, but able to resolve block.com.
Not sure whether you have mentioned the correct URL to be blocked. I guess you have masked the URL
alaeldien Wed, 01/21/2009 - 23:31
Hello
thank you for your quick reply
it is not the matter to choose between ip or url, because of name server being configured in the router can resolve url to ip address. the most important thing is that why i blocks all other site, inspite of
and
either of those 2 lines must allow other sites to be access able.
ok for being more clear i configuring the router with PPPoE that negotiate id address through ipcp and it is used virtual dialer for negotiation, do you think because of that, do i need to apply the ACL to physically connected interface?
thank you
thank
alaeldien Thu, 01/22/2009 - 02:54
Hello
i need someone please to refine the case and suggest to me interface that must the ACL applied to, assuming the 1841 router having only 2 fastethernet switch
int ethernet 0/0 facing local lan
int ethernet 0/1 facing ISP
please advice
shanbhag Thu, 01/22/2009 - 07:06
  • Cisco Employee,
Either way should be fine.
