Supported module for router
Answered Question
Jan 21st, 2009
I need a with following specifications for a Router Cisco 2821
These are the specification for the module
1000Base-LX/LH singlemode GBIC transceivers (operable over 1310nm or 1550nm range)
I tried to find it but I could not please help me in this regard.
Correct Answer by Tom Randstrom about 8 years 3 months ago
The HWIC-1GE-SFP is a card that installs in the router. Then you need to equip this card with an SFP optics module,the GLC-LH-SM (1310nm, singlemode fiber) looks like the one you are looking for.
HWIC-1GE-SFP
<http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/ge_hwic.html>
I hope this helps!
Overall Rating: 5 (1 ratings)
Tom Randstrom Thu, 01/22/2009 - 07:16
  • Gold, 750 points or more
From the documentation, 2821 switch does not support a GigE GBIC/SFP. The model 2851 equipped with either NME-XD-24ES-1S-P (1 SFP port) or NME-XD-48ES-1S-P (2 SFP ports) modules and can support the GLC-LX-SM SFP module (1300nm, singlemode fiber).
2800 Data Sheet
<http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html>
EtherSwitch Service Modules for Cisco 2800
<http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d15f.html>
Gigabit Ethernet Transceiver Modules Compatibility Matrix
<http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html>
viyuan700 Thu, 01/22/2009 - 12:15
  • Silver, 250 points or more
"2821 switch does not support a GigE GBIC/SFP"
Hi ,
I agree that 2821 dont support GBIC but i think it supports SFP, 2800 datasheet (link you have provided) says it supports HWIC-1GE-SFP Cisco Gigabit Ethernet High-Speed only 2801 dont support it as per that link.
I think NME cards are something different as they have 2310/100/1000 ports whereas i have seen just 2 FE ports and some slots for WAN interface and 2821 have 1 for High sped WAN interface (HWIC)
Tom Randstrom Thu, 01/22/2009 - 12:23
viyuan700,
It looks like you are correct. I overlooked that module in the list.
Per the compatibility matrix, the HWIC-1GE-SFP module, beginning with version 12.3(8)T4, supports the following SFPs:
GLC-T, GLC-SX-MM, GLC-LH-SM, GLC-ZX-SM
SFP-GE-T
Good catch!
m_aurangzeb Fri, 01/23/2009 - 10:55
Thanks to all
Nice work. I have asked the service provider that may i use HWIC-1GE-SFP in place of GBIC. I hope he will reply shortly.
One more thing to ask here that the Service Provider also said the module should be single mode but for HWIC-1GE-SFP i unable to find the specifications (1000Base-LX/LH singlemode GBIC transceivers ) for this module that was specified earlier by Service Provider.
I visited following link for this module but there is not such specifications
<http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016be8d.html>
Please help me in this regard.
Correct Answer
Tom Randstrom Fri, 01/23/2009 - 11:41
HWIC-1GE-SFP
I hope this helps!
m_aurangzeb Sat, 01/24/2009 - 09:19
Thanks a lot to all!
The world is really looking very good after this.
God Bless you.
Thanks again.
