FWSM running config in RME archive is not complete
Answered Question
Jan 22nd, 2009
I have a few FWSM contexts (Version 3.2(7)) which always appear in the Startup and Running Out-Of-Sync report.
The obvious reason is, that the "show running-config" command on the FWSM hides "asdm" commands, while "show startup" does include them.
IMHO, hiding commands from "show runn" is an insane idea in the first place. But I don't think I have a chance to get this fixed.
RME should cope with this problem, anyway.
The obviuos workaround would be to use "show running-config all" to archive the uncrippled running config.
Correct Answer by Joe Clarke about 8 years 4 months ago
I saw the internal discussion. There is apparently a lot of history on this, but a bug has been filed (CSCsx31925).
Overall Rating: 4 (1 ratings)
Joe Clarke Thu, 01/22/2009 - 07:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You could also add the asdm commands to the list of excluded commands under RME > Admin > Config Mgmt. This should get your report working for the time being.
g.meerkoetter Thu, 01/22/2009 - 07:20
Yes, thanks. I know that it would make the symptom disappear. But I'd rather see my config
archived completely.
Are you going to have that problem fixed?
Joe Clarke Thu, 01/22/2009 - 07:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'm unable to completely evaluate such a fix, as I don't have any FWSMs. I suggest you open a TAC Service request so a bug can be filed.
g.meerkoetter Wed, 01/28/2009 - 04:12
My SE has completely missed the point. :-(
I'm trying to get a more seasoned engineer...
Correct Answer
Joe Clarke Wed, 01/28/2009 - 08:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
g.meerkoetter Fri, 01/30/2009 - 01:56
Fixing the FWSM is a better solution than I dared to expect. Many thanks to Ramses who got that bug filed.
