Conference-Bridge CallManger
keynet
Hello
I need to run 140 conferences with 3 participants for each conference on a CallManager-Cluster 4.0. The cluster consist of 2 MCS-7825-H1-IPC1 server. A possiblitiy ist activate only the IP Voice Media Streaming service on the second of this server.
Does anyone have me an advice for this situation?
regards
Pascal
Jaime Valencia
you'll need to use the IPVMS on both servers since the max it can handle is 128 conferencees
If you stop the other services on the other server you might tweak the limitation a little bit to reach the 140 on that server
java
if this helps, please rate
java
Hello Java
Is it possible to configure a load-balancing between the servers? My idea is to give the second server 128 conferences and the first the rest. What to you think?
regards
Pascal
of course, once the CFB is over it's limit if you have another one you'll use it, you need to configure 2 MRG
java
java
