Notification alert - How to change IP Address become Device Name
Jan 22nd, 2009
My device IP address is 192.168.8.2 Can I change the IP become Device name?
EVENT ID = 00000S3
ALERT ID = 00000RU
TIME = Thu 22-Jan-2009 14:33:57 GMT+07:00
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 192.168.8.2
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = OperationallyDown::Component=IF-192.168.8.2/124 [Vl500] [10.1.1.1] [For Ap-Manager-Controller1];ComponentClass=Interface;ComponentEventCode=1075;Type=PROPVIRTUAL;IsFlapping=false;AdminStatus=NOTPRESENT;MaxSpeed=1000000000;OperStatus=NOTPRESENT;Interf
Joe Clarke Thu, 01/22/2009 - 07:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to make sure a one-to-one mapping exists either in DNS or the server's local hosts file. Once that is in place, remove the device from DFM, and re-sync it from DCR. IT should then show up by hostname.
