Location tracking
Jan 22nd, 2009
Hello
(We are getting a site survey)
Please see attached document
I need clarification on Location tracking
I am putting in an 802.11b/g wireless network to provide good data throughput for wireless clients
I also have a functional requirement to locate Rogue APs. At present the Location tracking device is unable to accurately detect rogues as they were deployed for coverage only. The network operators are spending a lot of time investigating the threat that rogues are on the floor only to find they are outside the building
I need to justify the expenditure of placing APs on the perimeter so that it's easy to identify if a Rogue AP is internal or external. If it's internal I am not that concerned with the accuracy as this will be taken care of with a visit to site by the network security team to investigate.
The AP deployment will be more of a coverage deployment in the centre of the floor
And a location tracking deployment on the perimeter.
I am considering putting the APs in monitor mode as I believe the receive sensitivity is increased in this mode so I will not require as many APs on the perimeter.
Does this sound like a good approach?
Can this be achieved without placing APs on the perimeter and calibrating the Location Appliance?
Overall Rating: 5 (1 ratings)
Scott Fella Thu, 01/22/2009 - 05:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Mark,
Placing the ap's in the perimeter will give you a better chance at knowing if the rouges are in or outside the perimeter wall. I wouldn't say it is 100% but it will give you a better reading that what you already have deployed. Again a site survey will really tell you if your mock up location will work or not, I think the biggest thing is that from every location you see at least 3 ap's at a -75db or better. Putting the ap's in monitor mode is fine especially on the right side of your drawing where you have dense areas. On the left side of your drawing, you can maybe put those in local mode to help with coverage and density if that is an issue. Calibration of the LA so far to me is a 50/50.... I have calibrated floor in which the location was worse than if I didn't and vice-versa.
You can also place your perimeter and then move your existing in more of a uniform pattern. Again... this depends on the survey... you might not need as much.
Scott Fella Thu, 01/22/2009 - 05:46
  • Hall of Fame,
    2017 Wireless
Here is an example.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
