Ldap Provider
Jan 22nd, 2009
Dear all,
I want to search the ldap directory with the user id,
I am using the LdapProvider class and its sendrequest method.
but iam confused in its parameters(filter and match rules)
how to give the function those parameters 4 example i want to search for a directory number "2005" how to format it.
Your fast response is really appreciated.
Marwa Ads
ivillegas Wed, 01/28/2009 - 06:33
Search filters are composed of attribute match requirements. For example, to construct a search filter to return all the entries in a directory that contain an attribute called uid with one value equal to testuser, the filter would be:
(uid = testuser)
