Cisco Catalyst 3560 Problem
Jan 22nd, 2009
hello,
i have a problem here , a switch was running and everything was ok the suddenly the system light went orange,
when i log on the switch using console i have this messege:
" the switch is not Usable"
i attached the show tech file to my mess.
can anyone help
regards
Dina
glen.grant Thu, 01/22/2009 - 04:28
I think the answer might be here , but in any case you have to rma the switch to cisco. It looks like a file error of some sort and also indicates a fan failure if the reading is correct. Reload and see if the error occurs again if so call cisco tac.
00:00:38: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
00:00:38: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_read_until (header) / file = / code = 21 (Is a directory) / bytes transfered = -1
-Traceback= ACCCB4 1A9838 1A58D0 8D6A6C 8CCFCC
00:00:40: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(25)SEE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 16-Jul-07 03:11 by myl
00:00:40: Unable to open UDP socket on CMP_PORT
------------------ show env all ------------------
FAN is FAULTY
TEMPERATURE is OK
POWER is OK
RPS is NOT PRESENT
