SHAIHAN JAFFREY Thu, 01/22/2009 - 04:21
Thanks cradescu, but one thing more now the edit softkey is visible but when i click it . It says "That key is not active here"
bmcghee Wed, 08/17/2016 - 07:59
I'm running into the same issue.  You press the sequence **# and get prompted for the password which you enter and still the get the "key is not active"  There's no way to disable the DHCP client if you cant get into network settings.  Any other ideas?
thank you..
