scottmac Thu, 01/22/2009 - 06:02
  • Green, 3000 points or more
Carl:
DO NOT UNDER ANY CIRCUMSTANCES LOOK INTO A FIBER OPTIC END UNLESS YOU KNOW, FOR A FACT, THAT IT IS DE-ENERGIZED!!!!!!!!!!!!!!!!!!!!!
NO kidding, no joke. Doing so can cost you your eyesight.
Single-mode uses wavelengths you cannot see, but are extremely strong and *WILL* burn a permanent line into your retina ... no recovery.
Even with Multimode and visible wavelengths, it is extremely bad practice to look into a fiber optic end ... unless you can see both ends, and neither are connected.
DO NOT, DO NOT, DO NOT look into a fiber optic end.
This also applies to fiber optic equipment (potentially live GBICS, SFPs, or other optical ports. Any unused ports should be plugged, even if the equipment automatically powers the port down on loss of signal ... don't risk your eyesight on some programmer's coding ability ... you know how things go with bugs and other "undocumented features."
Good Luck
Scott
viyuan700 Thu, 01/22/2009 - 07:03
  • Silver, 250 points or more
As already mentioned in other post singlemode are working on 1310nm & 1550nm range which are way beyond the visible spectrum (380-750nm).
In Multimode you can see those which operates at 850 nm close to red wavelngth.
Have you seen light at 1310nm range in Multimode?
scottmac Thu, 01/22/2009 - 08:33
Red is ~650nm.
850nm is near-IR (not visible)
viyuan700 Thu, 01/22/2009 - 11:15
"Red is ~650nm" Are you sure red is ONLY ~650nm? As far as i know there is no rule (like 2+2=4)that ~650nm is only red.
Is 200 near to 100 or 300?
scottmac Thu, 01/22/2009 - 12:51
Yes. I'm sure. Center red is 650 nanometers (6500 angstroms).
649 is trending to blue, and 651 is on the way to infrared/non-visible.
850nm is not visible.
What's your point?
