AS5350XM Power Supplies!!
Jan 22nd, 2009
hi,
I have a RAS (Model:AS5350XM) with two power supplies.I need to prove to the Customer that the power suplies are working in LOAD-SHARING MODE. Can some one have command sets or some Data Sheet proof depicting the load sharing behaviour of RAS power supplies?
drolemc Thu, 01/29/2009 - 06:57
  • Silver, 250 points or more
The power system consists of a single input AC or DC power supply or a dual input (redundant) AC or DC power supply. Cooling is provided by two self-contained fans. Each power module is capable of supplying a maximum DC load of 150 watts, and is composed of four independent output voltages: 3.3V, 5V, 12V, and -12V. AC input units have power factor correction, and low total harmonic distortion. Power failures are reported through environmental monitoring software. MGX-AC1-1 is for systems requiring a single AC power supply that is powered from a single AC power source. MGX-AC1-1 provides up to 1200 W of load-shared redundant power. If additional power is needed, additional power supplies, providing an additional 1200 W each, can be added
http://www.cisco.com/en/US/docs/routers/access/as5350xm/hardware/installation/guide/55chovr.html#wpxref94290
