Jaime Valencia Thu, 01/22/2009 - 08:13
  • Cisco Employee,
  • Hall of Fame,
    2011
no, they need to re-run the plugin to reconfigure all the files and keys related
java
if this helps, please rate
whanson Fri, 01/23/2009 - 08:02
just for reference if anyone cares about cm 4.x I found the directory ini file for the ad plug in noted the server name it was pointing to and created a host file with that name with the ip address of the dc that was put in place then restarted iis web cdr and tomcat which fixed the issue. Not pretty but it worked.
