01-22-2009 08:06 AM
Trying to change the default utilization value of 40% to higher value but it doesn't take it. Is there something I'm doing wrong? Just goes back to default value. This is on an interface 10/100MB Ethernet.
Solved! Go to Solution.
01-22-2009 08:30 AM
Exactly what version of DFM do you have? DFM 2.0 is very old, so I hope you're not using stock LMS 2.5.
If the settings are not saving at all (and you've clicked both Save and OK), this might be a browser issue. If you're using IE, try Mozilla. If you're using Mozilla, try IE.
01-22-2009 08:17 AM
Once you change the value, click Save then OK. Then, go to DFM > Configuration > Polling and Thresholds > Apply Changes, and apply your changes. Only then will the settings go into effect.
01-22-2009 08:27 AM
After hitting Apply Changes, I get: "Either you have not changed any settings or the settings you changed have been applied by a different user."
Any thoughts ? Thx.-
01-22-2009 08:30 AM
