01-22-2009 08:39 AM - edited 07-03-2021 05:02 PM
I want to use wireless 1250 series LAP with wireless controller 2112 series.The A.P frequency will be 2.4 Ghz.
01.To support wireless n or b,g wirless clients how many antenae we must use ?
Suppose I use only one omni 5.2 dbi antena on each access points?
02.I see there are 3+3 connectors on 1252 series a.p for antenae. does this means that 3 connectors for 2.4 Ghz and another 3 connectors for antena for 5.8 GHz?
03.Does this mean that (suppose we want 2.4 Ghz ) then each antena (out of three) will support different different radio (radio a ,radio g,radio wireless n) ?
plz advice in details...considering me lame man
Solved! Go to Solution.
01-22-2009 08:51 AM
Hi Abdul! It's a bit confusing getting going on the 1252s, so hopefully this helps a bit.
1. You only need one antenna to support all the protocols (a/b/g/n). However, adding more antennas increases functionality. You're no doubt used to seeing two antennas per AP in standard 802.11a/b/g networks, and this helps to reduce multipath interference, thus improving the quality of the wireless transmissions/receptions. However, to take advantage of all the features that makes 802.11n so great, you will need three antennas.
2. Correct, 3 are for the 2.4GHz range, 3 are for the 5GHz range.
3. There are actually only two radios in the 1252, and they are frequency-based (not protocol-based). In other words, there's a 2.4GHz radio (handling 802.11a/b/n) and a 5GHz radio (handling 802.11a/n). Notice that 802.11n operates in both frequency ranges. So, to answer your question, the 3 antennas work together to handle all the protocols on one frequency.
I hope that helps! Please feel free to post any follow-up questions.
Jeff
01-22-2009 08:51 AM
Jeff
01-26-2009 12:21 PM
hi jeff,
thnx alot.my concept clear now
thnx again.I am accessing net after many days.so replying late.
abdul
